Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5310 Optical Drive Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: Schritt 2, Bild 1 von 2 Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: Schritt 2, Bild 2 von 2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Optical Drive Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite C55-A5310 Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Optical Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C55-A5310 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
Abschluss
Kari Rodgers
482 Reputation
4 Anleitungen geschrieben
Sam Houston State, Team S16-G1, Nardone Spring 2018 Mitglied von Sam Houston State, Team S16-G1, Nardone Spring 2018
SHSU-NARDONE-S18S16G1
5 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 322
