Einleitung
A guide on how to replace the optical disk drive on a Toshiba Satellite C55-B5200 laptop.
Was du brauchst
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Make sure device is turned off and unplugged
Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
Remove the remaining two, 6.6 mm screws to remove the battery
Use a plastic opening tool to lift and open the back
Eine weitere Person hat diese Anleitung absolviert.
