Zum Hauptinhalt wechseln
Toshiba Satellite C55-B5302 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C55-B5302 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C55-B5302 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • The hard drive is held in place with a soft, blue rubber retainer. The retainer can be disconnected by pulling up on the two tabs at the left side of the hard drive in these images.
  6. Toshiba Satellite C55-B5302 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the hard drive away from the connection to remove it from the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,053
