Zum Hauptinhalt wechseln
Toshiba Satellite C55-B5302 laptop Memory chip (RAM) Replacement
Was du brauchst
  1. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: Schritt 2, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): Schritt 4, Bild 1 von 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): Schritt 4, Bild 2 von 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): Schritt 4, Bild 3 von 3
    • Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: Schritt 5, Bild 3 von 3
    • Push down on the two clips holding the RAM chip in place.
    • Pull the RAM chip up slightly and out away from the connection to remove.
Abschluss
Jessie
255 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 23
Insgesamt: 1,092
