Zum Hauptinhalt wechseln
Einleitung
If your battery is not working and you need to take it out, do the following steps to remove it properly.
  1. Make sure you turn off the laptop before starting. Remove the two 6.5mm PH1 Phillips screws securing the battery. Remove the two 6.5mm PH1 Phillips screws securing the battery.
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Abschluss
USF Tampa, Team S1-G5, Nance Spring 2017 Mitglied von USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 6
Letzten 30 Tage: 27
Insgesamt: 1,244
