Einleitung
The motherboard is a large and central part to the laptop. Most components either connect or interface with it in some manner. Because there is a lot involved, this guide will show how to remove it properly.
Was du brauchst
Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
Using the plastic opening tools, open the back cover and remove it from the laptop.
The hard drive is on the bottom left side.
Remove both releases from the rubber hard drive mount.
Lift the hard drive from underneath on the right side.
While holding it up, pull it away from its connector so that it disconnects.
Slide the disk drive to the right and gently lift up the disk out the laptop.
Disconnect the 5 ribbon cables.
To remove, unlock the latch of each ribbon and pull it out.
There is a wifi card underneath the large ribbon cable on the right.
Remove the plastic piece that covers the screw.
Unscrew the PH1 Phillips head 3.0 mm long screw holding it in.
Pull out the WiFi card.
Unscrew the seven PH1 Phillips head 3.0 mm long screws that hold the motherboard in place.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
