Zum Hauptinhalt wechseln
Toshiba Satellite C55-C5268 Back Panel Replacement Guide
Was du brauchst
  1. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Battery: Schritt 1, Bild 1 von 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: Schritt 2, Bild 1 von 2 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: Schritt 2, Bild 2 von 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Back Panel: Schritt 3, Bild 1 von 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: Schritt 4, Bild 1 von 2 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: Schritt 4, Bild 2 von 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: Schritt 5, Bild 1 von 2 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: Schritt 5, Bild 2 von 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 4-1, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 1,831
