Zum Hauptinhalt wechseln
Toshiba Satellite C55D-A5201 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 9, Bild 1 von 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 9, Bild 2 von 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Kari Byrd
614 Reputation
1 Anleitung geschrieben
Baylor, Team 6-5, Shaver Spring 2015 Mitglied von Baylor, Team 6-5, Shaver Spring 2015
BU-SHAVER-S15S6G5
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 5,820
