Einleitung
If the fan is excessively noisy or non-operational, use this guide to remove and replace the fan.
  1. Turn off your laptop before starting. Flip the laptop over so the model stickers face the ceiling.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver. Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver. Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver.
    • Remove the two 7 mm Phillips screws holding the battery using the PH1 bit and Magnetic Driver.
  3. Carefully slide the battery out of the laptop. Carefully slide the battery out of the laptop.
    • Carefully slide the battery out of the laptop.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the remaining thirteen 7 mm Phillips screws holding the back cover  using the PH1 bit and Magnetic Driver.
    • Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
  6. Using the plastic opening tools, separate the back cover from the laptop. It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Using the plastic opening tools, separate the back cover from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  7. Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver. Lift the fan cable connector from the fan. Lift the fan cable connector from the fan.
    • Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
    • Lift the fan cable connector from the fan.
  8. Remove the fan from the plug by releasing the clamps located on each side of the socket. Slide the connector out of the socket. Lift the computer fan from the motherboard.
    • Remove the fan from the plug by releasing the clamps located on each side of the socket.
    • Slide the connector out of the socket.
    • Lift the computer fan from the motherboard.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 225
