Einleitung
If you are unable to use the touchpad of your laptop, use this guide to remove and replace the touchpad.
Was du brauchst
Now begin to remove the coverings above and below the middle plate with your hand.
use your hand or a tool to remove the tabbing on the metal plate covering the battery.
grab your replacement keyboard and connect it to the backing of the old keyboard.
once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Release the clamps holding the white ribbon between the touchpad component and the motherboard.
Slide the ribbon from the motherboard connection socket.
Remove the two 7 mm Phillips screws holding the touchpad component to the back panel using the PH1 bit and Magnetic Driver.
Release the two clamps connecting the blue ribbon to the external touchpad.
Lift the black clasp holding the blue ribbon in place.
Slide the blue ribbon from the external touchpad holding socket.
Lift the touchpad module from the laptop.
