Einleitung
In the case you may need to replace a key on your Toshiba Satellite C55D-C5106 keyboard, this manual is meant to guide you along the process.
Was du brauchst
Open the laptop, turn it off, and remove any external power sources before you remove any keys.
Identify which key needs to be replaced and make sure you have an identical, functioning key on hand.
Fast fertig!
Abschluss
