Einleitung
This guide will serve as a prerequisite and show users how to take apart the device.
Was du brauchst
Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
Fast fertig!
Ziellinie
