Einleitung
This guide will show you how to replace the keyboard on your Toshiba Satellite C55Dt-A5306.
Was du brauchst
After removing the battery, open up your device so that the keyboard is facing you.
Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
You can now remove the keyboard.
