Zum Hauptinhalt wechseln
Toshiba Satellite C855-S5115 DVD Tray Replacement
Was du brauchst
  1. Toshiba Satellite C855-S5115 DVD Tray Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  2. Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 2, Bild 3 von 3
    • Pry the back panel out of the laptop using the spudger tool
  3. Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 3, Bild 2 von 2
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  4. Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 4, Bild 2 von 2
    • Slide the HDD towards the sticker on the left.
  5. Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
  6. Toshiba Satellite C855-S5115 DVD Tray Replacement, DVD Tray: Schritt 6, Bild 1 von 1
    • Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
  7. Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 7, Bild 2 von 2
    • Insert a plastic opening tool and follow the edges to open the panel.
  8. Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 8, Bild 1 von 1
    • Once open, locate the CD tray indicated in this picture.
  9. Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: Schritt 9, Bild 2 von 2
    • Lift the tray up and out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 272
