Einleitung
This guide will show you how to remove your laptops battery. This process requires no tools; just your hands! When doing this, make sure that the device is powered off and not hot from recent usage.
Lay your laptop upside down on a flat surface.
Power off your laptop and unplug the charger.
Locate the right eject switch, labeled "1".
Slide the switch all the way to the right and it should stay in place.
The second eject switch is on the left and it is numbered "2".
Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
With hand still pushing the left switch, grab onto notch at the center of the two switches.
Pull up and towards you. The battery will begin to lift out of the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
