Einleitung
This guide will show you how to remove your laptops RAM. This process requires a small Phillips Head screwdriver and your hands. There will be several small screws removed, so be sure you have a place to store them as you work to keep from losing any.
Was du brauchst
Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
Once the screw is removed, pry the panel upwards by gripping the groove pictured.
Using the curved tweezers from the Precision Tweezers Set grab and pull the metal clips away from each side of the RAM.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
