Zum Hauptinhalt wechseln
Toshiba Satellite C875-S7304 RAM Replacement
Was du brauchst
  1. Toshiba Satellite C875-S7304 RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite C875-S7304 RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite C875-S7304 RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C875-S7304 RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 RAM Replacement: Schritt 3, Bild 1 von 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 RAM Replacement: Schritt 4, Bild 1 von 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 RAM Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 RAM Replacement, RAM: Schritt 6, Bild 1 von 1
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  7. Toshiba Satellite C875-S7304 RAM Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite C875-S7304 RAM Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite C875-S7304 RAM Replacement: Schritt 7, Bild 3 von 3
    • Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
    • Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
    • Repeat the steps above on the left side of the hard drive/RAM panel.
    • Pull the cover towards you and up from the device to remove it.
    • Hearing a popping noise while wedging the plastic opening tool is normal.
  8. Toshiba Satellite C875-S7304 RAM Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite C875-S7304 RAM Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite C875-S7304 RAM Replacement: Schritt 8, Bild 3 von 3
    • Push outward on the metal tabs to unclasp the RAM from its slot.
    • With the RAM unclasped at a slight angle, carefully pull it out with two hands.
    • When reassembling, remember to align the indentation on the RAM with the indentation on its slot.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Taimoor Arshad
381 Reputation
2 Anleitungen geschrieben
University of Alabama, Team S2-G5, Bedsole Fall 2019 Mitglied von University of Alabama, Team S2-G5, Bedsole Fall 2019
UA-BEDSOLE-F19S2G5
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 943
