Einleitung
This guide will walk you through step by step on how to replace the screen display assembly on a Toshiba Satellite CL15t-b1204x. The screen display is vulnerable to any type of physical damage, whether that be from exposure to liquids or screen crackings. It may also need to be replaced if it stops working after a long period of time. One thing to keep in mind, is that the display comes as a full assembly, and a new assembly can be ordered online.
Was du brauchst
Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
Eine weitere Person hat diese Anleitung absolviert.
