Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The battery supplies the device with power without having to keep the device plugged into a charger. If your device will not turn on, try plugging it into the charger. If that doesn't work, use this guide to replace the battery.
  1. Slide both of the latches to the outside to release the battery. Slide both of the latches to the outside to release the battery.
    • Slide both of the latches to the outside to release the battery.
  2. Pull the battery out by lifting the battery cover away from the laptop. Pull the battery out by lifting the battery cover away from the laptop.
    • Pull the battery out by lifting the battery cover away from the laptop.
Abschluss
Andrew Godsil
35 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-21, Forte Winter 2013 Mitglied von Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 593
