Zum Hauptinhalt wechseln
Toshiba Satellite E45t-B4204 Fan Replacement
Was du brauchst
  1. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: Schritt 1, Bild 1 von 3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: Schritt 1, Bild 2 von 3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 2, Bild 2 von 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 3, Bild 3 von 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Fan Replacement, Fan: Schritt 4, Bild 1 von 1
    • Locate the fan.
    • The fan is a grey plastic with a black circular fan in the center.
  5. Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove all 4 mm screws with a Phillips #1 screwdriver.
  6. Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 6, Bild 2 von 2
    • Locate the red, black, and yellow wire connecting to the motherboard.
  7. Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite E45t-B4204 Fan Replacement: Schritt 7, Bild 3 von 3
    • Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
Abschluss
Perla Ruiz
159 Reputation
1 Anleitung geschrieben
Sam Houston State, Team S17-G4, Blackburne Spring 2018 Mitglied von Sam Houston State, Team S17-G4, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 248
