Einleitung
This guide will explain the process of removing the keyboard in the Toshiba Satellite E45t-B4204. Keyboard removal requires nearly all major components being removed to
Was du brauchst
Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
Remove the back case.
Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
Remove speakers.
Unscrew the keyboard cover using the Phillips #0 screwdriver.
Unscrew the keyboard cover using the #1 screwdriver.
Ein Kommentar
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
