Zum Hauptinhalt wechseln
Toshiba Satellite L15W-B1320 Battery Replacement
Was du brauchst
  1. Toshiba Satellite L15W-B1320 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Battery Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite L15W-B1320 Battery Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite L15W-B1320 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
Abschluss
Elizabeth Zapata
190 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 1,231
