Zum Hauptinhalt wechseln
Toshiba Satellite L305-S5955 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Complete these steps in reverse order to insert hard drive back into laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric
55 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-2, Buehl Fall 2014 Mitglied von Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 16
Insgesamt: 956
