Zum Hauptinhalt wechseln
Toshiba Satellite L305-S5955 Wireless Card Replacement
Was du brauchst
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: Schritt 1, Bild 1 von 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 6, Bild 2 von 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: Schritt 7, Bild 1 von 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: Schritt 7, Bild 2 von 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: Schritt 7, Bild 3 von 3
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 8, Bild 1 von 1
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: Schritt 9, Bild 1 von 1
    • Pull the card out vertically.
Abschluss
Samuel Baker
307 Reputation
3 Anleitungen geschrieben
IUPUI, Team 1-2, Baechle Spring 2017 Mitglied von IUPUI, Team 1-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 791
