Einleitung
This guide will show you how to change the Battery for the Toshiba Satellite L305D-S5895.
Was du brauchst
Make sure switch with the number 1 is moved to the right, in the unlocked position.
Slide and hold switch number 2 to the left, and use your finger to pry battery out using the slot to the right of the switch.
Eine weitere Person hat diese Anleitung absolviert.
