Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Toshiba Satellite L305D-S5950 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 2 Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: Schritt 5, Bild 2 von 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the keyboard completely from the laptop.
Abschluss
William
869 Reputation
7 Anleitungen geschrieben
Clemson, Team 1-2, Benson Spring 2014 Mitglied von Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
I have a Toshiba Satellite L305D. A glass of tea was spilled on it several months ago and I just turned it on and it is working but some of the keys do not work, shift, letter a and several more. If I replace the keyboard will this fix this problem or are there more parts that should be replaced? Thanks, Pam
pamtinkle - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 5
Insgesamt: 477
