Einleitung
In order to replace the motherboard the hard drive, RAM, keyboard and motherboard cover need to be removed.
Was du brauchst
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Remove the cover by lifting the right side up at an angle before removing the entire cover.
Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
Lift up the top of the keyboard to remove it.
Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
Unplug the ribbon cable from the laptop.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
Unplug the wires highlighted with red squares.
Using a pry tool and yours hands to remove the motherboard cover.
Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
Unplug all the wires indicated by the orange squares.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
