Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
To reassemble your device, follow these instructions in reverse order. When placing the RAM chips in, push them down until the levers snap into place after inserting them into the slot.
