Zum Hauptinhalt wechseln
Toshiba Satellite L35-S2174 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite L35-S2174 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Use a J1 screwdriver to unscrew the two circled screws. The screws will remain attached to the plastic panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Slide the hard drive to the left to detach it from the computer.
    • Lift the hard drive from the computer.
Abschluss
Amani Mitchell
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-4, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 562
