Zum Hauptinhalt wechseln
Toshiba Satellite L35-S2174 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite L35-S2174 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 2 Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: Schritt 5, Bild 2 von 2
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
Abschluss
Amani Mitchell
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-4, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 337
