Einleitung
The keyboard allows you to control your computer. If the keyboard isn't working, it jmay cause many problems with computer interactions. Replacing the keyboard can fix keyboard-related mechanical problems.
Was du brauchst
Use a spudger to pry up the plastic panel between the keyboard the screen.
Repeat on opposite side of laptop.
Tilt the laptop's screen back.
Lift the panel and remove it from the laptop.
Unclip the keyboard from the laptop by lifting it.
Slide the keyboard slightly towards the screen.
Lift the keyboard out of the way.
