Einleitung
The Power Jack for the Toshiba Satellite L355/L305 series is damaged after many uses and will most likely need to be replaced. In this guide you will find a permanent solution to the common problem.
In order to repair/replace the Power Jack it is necessary to disassemble the laptop.
Was du brauchst
Now that your Toshiba L355 laptop battery is unlocked, find the battery release button down.
Holding the laptop battery release button, gently pull your battery away from the laptop.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
