Einleitung
The dial up modem allows the user to connect to the internet through a wired connection if a wireless source is not available. This guide shows to the user how to replace the dial up modem if it is not functioning properly.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Make sure the battery lock switch is switched to the unlocked position. The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock. The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Slide the battery release switch to the left. The switch is spring loaded, so you must hold the switch in place while removing the battery.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Using a finger, lift up the battery. The battery release switch must be held in place.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the 5 Phillips screws holding the panel in place. These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss. These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  6. Use a finger to remove the panel by lifting up on the provided removal tab. Use a finger to remove the panel by lifting up on the provided removal tab. Use a finger to remove the panel by lifting up on the provided removal tab.
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  7. Remove the two screws holding modem in place. Two 3.6 mm Phillips screws.
    • Remove the two screws holding modem in place.
    • Two 3.6 mm Phillips screws.
  8. Using a plastic removal tool, dislodge the modem. This separates a small connections on the underside of the modem. Using a plastic removal tool, dislodge the modem. This separates a small connections on the underside of the modem.
    • Using a plastic removal tool, dislodge the modem. This separates a small connections on the underside of the modem.
  9. Grab the black insert connected to the modem. Gently pull the insert outwards to disconnect the cable. Grab the black insert connected to the modem. Gently pull the insert outwards to disconnect the cable. Grab the black insert connected to the modem. Gently pull the insert outwards to disconnect the cable.
    • Grab the black insert connected to the modem. Gently pull the insert outwards to disconnect the cable.
Abschluss
Stephen Sippel
167 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 21-54, Johann Spring 2013 Mitglied von Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Mitglieder
Does someone know anything about the modem connector connecting the modem to the motherboard? Any information like part number, name, manufacturer would be handy.
Kamil - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 562
