Einleitung
The hard drive stores all of the critical information required by the laptop for proper functioning and saves all the data files created by the user. The hard drive is designed to be easily removed to allow for easy replacement in cases where the device breaks or upgraded if the user requires more memory.
Was du brauchst
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the screws attaching the hard drive and bracket.
Four 4.6 mm Phillips screws.
Lift up the black tab to expose hard drive.
Grab the hard drive bracket and pull to remove.
Remove the screws attaching the hard drive to hard drive bracket.
Four 3.6 mm Phillips screws.
