Zum Hauptinhalt wechseln
Toshiba Satellite L45-S7423 RAM Replacement
Was du brauchst
  1. Toshiba Satellite L45-S7423 RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite L45-S7423 RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite L45-S7423 RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L45-S7423 RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 RAM Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L45-S7423 RAM Replacement: Schritt 3, Bild 2 von 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 RAM Replacement, Bottom Access Panel: Schritt 4, Bild 1 von 3 Toshiba Satellite L45-S7423 RAM Replacement, Bottom Access Panel: Schritt 4, Bild 2 von 3 Toshiba Satellite L45-S7423 RAM Replacement, Bottom Access Panel: Schritt 4, Bild 3 von 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 RAM Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite L45-S7423 RAM Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite L45-S7423 RAM Replacement: Schritt 5, Bild 3 von 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 RAM Replacement, RAM: Schritt 6, Bild 1 von 3 Toshiba Satellite L45-S7423 RAM Replacement, RAM: Schritt 6, Bild 2 von 3 Toshiba Satellite L45-S7423 RAM Replacement, RAM: Schritt 6, Bild 3 von 3
    • Pull apart the two tabs holding the RAM in place.
  7. Toshiba Satellite L45-S7423 RAM Replacement: Schritt 7, Bild 1 von 1
    • Upon release, RAM will automatically pop up.
  8. Toshiba Satellite L45-S7423 RAM Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite L45-S7423 RAM Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite L45-S7423 RAM Replacement: Schritt 8, Bild 3 von 3
    • Gently pull on RAM to remove.
Abschluss
Cal Poly, Team 21-54, Johann Spring 2013 Mitglied von Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 1,541
