Einleitung
In this guide we will teach you how to replace the keyboard of your laptop.
Was du brauchst
Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
Remove the keyboard slowly. It will be attached to the laptop by a plastic connector, which can be disconnected from the laptop by pulling gently.
Fast fertig!
Abschluss
