Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide is useful for replacing a broken keyboard on your Toshiba Satellite L455-S5975. In this replacement guide, you will remove the old keyboard and install the new one.
Note: Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery. Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Remove the three 3mm screws with a Phillips#00 Screwdriver.
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Lift the keyboard away from the top side of the laptop.
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  5. Disconnect the keyboard cable that is still attached to the keyboard. Unlatch the fastener.
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Mike Kennedy
133 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 2-21, Maness Spring 2013 Mitglied von Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 9
Insgesamt: 2,038
