Einleitung
Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Was du brauchst
Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
Disconnect the keyboard cable that is still attached to the keyboard.
Unlatch the fastener.
Using your hands, pull the keyboard connector out, not up.
Flip the laptop over to access the battery.
Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
Remove the twelve 10mm screws with a Phillips #00 screwdriver.
Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
Flip the laptop over so it's in the right-side-up position.
Lift the grey plastic casing up and unhook any wires attached to the casing.
Remove the five 10mm screws, each with a label 'F10' next to them.
Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
Disconnect the thin red wire on the right side of the motherboard.
Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
Remove the fan.
Remove the following with a Phillips #00 Screwdriver:
Six 7mm Phillips Head screws
One 5 mm Phillips Head screw
Remove the LCD screen tab
A red wire connects the motherboard to the computer, so release the wire by pulling it straight out.
After all the screws are removed, lift the motherboard up and away from the earphone jacks that are located at the front of the laptop.
Eine weitere Person hat diese Anleitung absolviert.
