Zum Hauptinhalt wechseln
Toshiba Satellite L455-S5975 WiFi Card Replacement
Was du brauchst
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: Schritt 1, Bild 1 von 1
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 2, Bild 2 von 2
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 3, Bild 3 von 3
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite L455-S5975 WiFi Card Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the wifi card from the laptop.
Abschluss
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Dylan Baker
188 Reputation
1 Anleitung geschrieben
UMD team 2 Mitglied von UMD team 2
Community
4 Mitglieder
Ein Kommentar
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 2,241
