Einleitung
The battery is the easiest component to replace on this laptop since it requires only your fingers, as there is no screw to remove in order to access the battery.
Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
