Zum Hauptinhalt wechseln
Toshiba Satellite L505 Laptop Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite L505 Laptop Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite L505 Laptop Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite L505 Laptop Keyboard Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite L505 Laptop Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Matias
1.019 Reputation
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 1,202
