Zum Hauptinhalt wechseln
Toshiba Satellite L655D-S5095 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite L655D-S5095 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jerry Wakai
377 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 7-7, Maness Winter 2013 Mitglied von Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - Antwort
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 4,923
