Zum Hauptinhalt wechseln
Toshiba Satellite L755D-S5150 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
Abschluss
Replace after you are done with your goal replacement.
Eine weitere Person hat diese Anleitung absolviert.
Shaheedah
276 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 2-5, Sullivan Fall 2016 Mitglied von USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 881
