Was du brauchst
There is a cut-out space in the CD/DVD bay. This is where you would use your finger to push and nudge the keyboard from its clip.
Turn the laptop right side up, open the LCD so the keyboard is exposed.
Firmly push the keyboard upward from the space in the CD/DVD bay. You should feel the clip being released from its hinge.
Use a thin blade knife or spudger to release all the clips along the bottom edge of the keyboard.
After all the clips have been released, simply pull the keyboard downward to remove it from the top hinges.
Remove the ribbon cable from the socket to remove the old keyboard.
To install the new keyboard, insert the ribbon cable and press the clips back in place.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Where can I find a replacement keyboard? just search ebay, or is there a better option?
I bought mine from eBay and just changedn it, and it's all groovy now.
look for replacement keyboard part no and get it.
Then watch videos how to unclip the keyboard and how to unclip the ribbon.
Then comeback and follow these steps here
chiedu7 -
I own a Toshiba Satellite L850D model and I bought a replacement keyboard, but I am having a problem, I can’t get the friggin’ keyboard out! You guys make it look easy yet I am struggling to get out the keyboard. How should I do it? Also, how do get the trackpad working again? It no longer works now.
