Zum Hauptinhalt wechseln
Toshiba Satellite L875D-S7210 Screen Replacement
Was du brauchst
  1. Toshiba Satellite L875D-S7210 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Locate the round stickers on each corner of the screen covering the screws. Use a sharp tool, such as a pointy metal spudger or tweezers, to gently remove these stickers.
  2. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the screws using a Phillips Head #1 screwdriver; there should be four in total, one on each corner.
  3. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 3, Bild 1 von 1
    • Take the opening tool and gently place it under the plastic framing the screen. Gently slip the opening tool between the plastic frame and the screen, until a change in pressure is felt, the feeling of the plastic clasps dislodging.
  4. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 4, Bild 1 von 1
    • Repeat this process along the interior edges of the plastic frame. Once the all plastic locks are unhooked the plastic frame should fall off the screen.
  5. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 5, Bild 1 von 1
    • Locate the two screws at the bottom corners of the screen.
  6. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 6, Bild 1 von 1
    • Using the same screwdriver (Phillips Head #1), unscrew all the screws on both sides of the screen.
  7. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 7, Bild 1 von 1
    • Find and unscrew the six screws (3 on each side) on the sides of the screen. Be careful while unscrewing the last few screws as the screen will still be attached to the computer in two different places and may fall out of its casing.
  8. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 8, Bild 1 von 1
    • At the top of the computer, there should be a cable still wired to the detached screen. Gently pull the head of the cable away from its connector until the cable dislodges.
  9. Toshiba Satellite L875D-S7210 Screen Replacement: Schritt 9, Bild 1 von 1
    • At the back of the screen, there will be one more connector at the bottom. Remove the tape to disconnect this wire.
Abschluss
Ian M Sloop
667 Reputation
4 Anleitungen geschrieben
UC Davis, Team S7-G7, Lore Fall 2018 Mitglied von UC Davis, Team S7-G7, Lore Fall 2018
UCD-LORE-F18S7G7
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 303
