Einleitung
If your disk drive is not reading any disks or can not open, then this guide will help you quickly replace it.
Was du brauchst
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Slide and hold the tab on the right side of the battery to the right.
While holding the right tab, slide the battery upward and out its socket.
Remove the 8mm Phillips #1 screw that holds the disk drive in place.
