Einleitung
This is a guide to replace a malfunctioning keyboard. This guide will teach you how to unscrew your keyboard and remove the ribbon cable to allow you to replace the keyboard.
Was du brauchst
Place the laptop with the screen facing you and grab the opening tool.
Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
You will feel the popping sensation as it slides along.
To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
