Einleitung
This guide will show how to remove the screen on the Toshiba Satellite.
Was du brauchst
With the screen on a flat surface, remove the screws in each corner of the screen. There will be 4 in total.
Note: The screws for the screen may be hidden under rubber pad at the top of the screen so they will have to be removed.
After the front cover is removed remove the two screws at the very bottom of the screen.
Remove the four screws on the each side of the screen. There will be eight in total.
Lay the screen flat on the keyboard so they the back panel can be accessed.
Remove all the tape on the video cable that connects the screen to the computer.
Remove the video cable from the screen.
After the video cable is removed the screen is free and can be removed from the computer.
