Einleitung
The battery is the main source of the device. Be sure to unplug the device from any power source before attempting to remove the battery.
Was du brauchst
Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
Unscrew the four 5 mm JIS #1 head screws holding the battery to the device and gently remove the battery.
Disconnect the battery from the motherboard by gently pulling out the black connector.
