Zum Hauptinhalt wechseln
Toshiba Satellite P55W-C5200X Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: Schritt 6, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: Schritt 6, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: Schritt 6, Bild 3 von 3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: Schritt 7, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: Schritt 7, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: Schritt 7, Bild 3 von 3
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: Schritt 10, Bild 1 von 1
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 11, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 11, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 11, Bild 3 von 3
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 12, Bild 1 von 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 13, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 13, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 13, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 14, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 14, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 14, Bild 3 von 3
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 15, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 15, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 15, Bild 3 von 3
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 16, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 16, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 16, Bild 3 von 3
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 17, Bild 1 von 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 17, Bild 2 von 2
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 18, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 18, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 18, Bild 3 von 3
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 19, Bild 1 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 19, Bild 2 von 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: Schritt 19, Bild 3 von 3
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G2, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G2
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 1,348
